PWM
GPIO应用 - PWM章节中通过给指定的文件内写入数值来操作硬件pwm,如果想用C语言控制pwm,只要调用C语言提供的读写文件的函数去操作那些文件即可。
例程-操作PWM1-1输出
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <unistd.h>
#include <string.h>
char *control_path[4] = {
"/sys/class/pwm/pwmchip0",
"/sys/class/pwm/pwmchip16",
"/sys/class/pwm/pwmchip20",
"/sys/class/pwm/pwmchip22",
* 将字符串写入指定文件
* @param path 文件路径
* @param str 要写入的字符串
void write_to_file(char *path, char *str)
int fd;
fd = open(path, O_WRONLY);
if (fd < 0)
printf("open file error: %s\n", path);
exit(-1);
write(fd, str, strlen(str));
close(fd);
* 导出PWM通道
* @param control 控制器编号0 1 2 3
* @param channel PWM通道号
void pwm_export(int control, int channel)
char path[100];
char str[10];
sprintf(path, "%s/export", control_path[control]); // 生成export文件的路径
sprintf(str, "%d", channel);
write_to_file(path, str);
* 配置PWM通道的参数。
* @param period PWM信号的周期,单位为纳秒。
* @param duty_cycle PWM信号的高电平时长。
void pwm_config(int control, int channel, int period, int duty_cycle)
char str[10];
char path[100];
sprintf(path, "%s/pwm%d/period", control_path[control], channel);
sprintf(str, "%d", period);
sprintf(path, "%s/pwm%d/duty_cycle", control_path[control], channel);
sprintf(str, "%d", duty_cycle);
sprintf(path, "%s/pwm%d/polarity", control_path[control], channel);
write_to_file(path, "normal");
* 启用PWM通道的输出。
void pwm_enable(int control, int channel)
char str[10];
char path[100];
sprintf(path, "%s/pwm%d/enable", control_path[control], channel);
write_to_file(path, "1");
* 关闭PWM通道的输出。
void pwm_disable(int control, int channel)
char str[10];
char path[100];
write_to_file(path, "0");
int main()
pwm_export(1, 1); // 导出PWM通道
pwm_config(1, 1, 10000000, 5000000); // 配置PWM周期和占空比
pwm_enable(1, 1); // 启用PWM输出
return 0;
上面代码中通过下面3个语句配置PWM输出。其中 pwm_config(1, 1, 10000000, 5000000);
- (1,1) 表示定时器1,通道1
- 周期时间 10000000ns, 即10ms, 频率为:1s/10ms=100Hz;
- 高电平时间 5000000ns, 即5ms, 占空比为:5ms/10ms = 50%
下面为输出引脚和输出结果:
